Building management systems - Fire Alarms
I hope that you can help - I have a query.
I am looking at a centralised team that monitors buildings remotely - the alarms that we handle come in from a dedicated BMS panel and as you can imagine we handle a significant number of alarms or rather activations as thankfully the majority of activations are not real alarms.
We did a study on this and found that if we put in a delay then we could have a significant reduction of spurious to our system. It may appear to be the ideal solution but I have a couple of concerns - the majority of the buildings are uk based and I am wary of adding a delay if this would contravene any building regulations.
I know its not the actual alarm that is being altered but rather the repeater - if say a minute was added then this would provide a positive reduction to handled alarms back at the monitoring point.
RE: Building management systems - Fire Alarms
It is a risk as you say, and knowing the uk with the way they like to control risks.....!
