Switching Drawing/Model hotkey?
I recently switched from SolidWorks to NX and I am used to switching to different drawings by using: ctrl+tab & ctrl+shift+tab.
Does NX have anything like this?
I appreciate any help
RE: Switching Drawing/Model hotkey?
Are you talking about switching to different Drawing sheets within the same part file? If so, that's done from the Part Navigator or by going to the 'Open Sheet' command. Out-of-the-box, there is no 'hotkey' defined for the Open Sheet command, but there's no reason you couldn't use Customize to assign a Hotkey. However, there is NO support for any hotkey using any sort of 'Ctrl+Tab' combination (it's not allowed). Note that there is NO support for any COMBINATION of 'Ctrl', 'Tab', 'Alt', 'Fn', etc.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
