Drafting with Equation driven models
I am having an issue with a project I am working on and I am wondering if anyone on the forum has dealt with a related issue.
I have an assembly created that draws variables off an excel sheet to generate a fairly simple assembly.
My issue is that the changes in length alter the layout of my draft. I would like to have a variable driven view break in my draft, but edge won't let me define the break with a variable I can alter with the variable table.
Has anyone here had to deal with this layout problem, and is there an elegant solution to allow automatic/easy changes to sheet layouts?
RE: Drafting with Equation driven models
I ended up going into the advanced properties of each view and turning off the option to remove geometry not shown in the view box. I could then define each view and use multiple copies of each to create a section view that stayed mostly static as the parametric changed.
I am using ST3. This may change things if you are not.
