when does it want to use barred tee
hi every body,
please help for this.
question: the barred tee is used for expand a connection to the branch of available for pigging pipeline. but for small diameter branch, it does not want the barred tee. how nuch does the limited ratio of mainline diameter to branch diameter for chosing to use barred tee?
thank
thank
RE: when does it want to use barred tee
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
