NX Export PDF function and printing
I recently was using NX 7.5.4.4 (x64), I have since uninstalled that version and I am now running NX 7.5.5.4 (x32), I am not able to print or Export PDF's. This worked fine in the 64bit version. When I go to print it says UGII_SDI_BASE incorrect, but when I checked the path it is correct. When I go to export PDF's it says "Unknown System Error".
RE: NX Export PDF function and printing
GTAC should be able to resolve this for you.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Got it fixed, I guess it would help if I installed NXPlot!
