Casting Stress Cracks?
I've gotten involved with a casting issue, and to be honest, castings are far from my normal subject matter,-- so please forgive me if this question is basic knowledge.
We've had a casting made that resembles a large shoebox. Overall dims are 26in long, 10in wide, and about 6in deep and the walls are about 1in thk. Material is cast ductile iron. For some reason, the original designer kept the inside corners fairly sharp (about 1/8in rad). Once the castings were made amd some surfaces machined, we noticed cracks in some of the internal corners (assumed to be stress cracks from cooling?).
The question is can this casting be used? can it be repaired? will the cracks almost be guarenteed to continue growing?
I realize a lot of this is very vague, but hopefully it is a starting point for discussion.
RE: Casting Stress Cracks?
http://www.aera.org/ep/downloads/ep9/EPQ110_20-27....
http://www.ductile.org/magazine/2007_2/ductileweld...
http://www.lincolnelectric.com/en-us/support/weldi...
http://fulltorque.com/pdf/GMRC%20white%20paper.pdf
I would not suggest salvaging such cracks for DI castings.
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
