Is this the right mixer for my application?
Vessel: 38"W x 45"D x 45"H
Volume: 320 gallons
Motor: 1 HP
Impeller: one 9” hydrofoil located about 10” from bottom of tank
Fluid Viscosity: 35 cP
Type: Suspension of solid particles in Ethylene Glycol
Mixer drops shaft into solution at slight angle from one of the top edges of the cubical vessel towards the center of the tank.
RE: Is this the right mixer for my application?
It will probably work okay, but having corners in the tank might allows for sedimentation there.
