Best way to fabricate this large steel motor enclosure?
I'm working on a motor enclosure design for a large electric motor. Originally it was designed as a one-piece solid cast part. I've been instructed to make a machined design instead. my plan is to take the original cast design and break it up into sections which would be welded together. after some initial sketches, I'm not happy with how the design looks structurally. based on the attached sketches, am i taking the right approach or is there a better way of doing this? i'm mostly concerned with the tubular section of the housing. i figured that my two options would be to (1) weld tubes together, or (2) machine from one larger/thicker tube (i would probably to start with a 6" thick tube and machine down.
I would greatly appreciate any tips or advice. some section views are attached for reference. The pdf contains 3 images. The first is a 3-D view, second is a cross-section of the one-piece design, and the third image is a sketch of were i'm planing to break up into section.
Wall Thickness = 2.0 in
Max Outer Diam = 46 in
Min Inner Diam = 34 in
I plan on doing a full FEA, modal analysis, and dynamic analysis once i feel that i have a cost effective solution.
RE: Best way to fabricate this large steel motor enclosure?
Heavy walled tubing is a seamless tubing product. Thin walled tubing 5/8" or smaller is an ERW product.
Bill
as Bill suggested, & as follows",
you need to take your drawings to sheet metal fabricated of heavy wall pipe & welding.
The flanges can be made from plate, the pipe can be Brake formed, rolled & welded, the various diameters can be fabricated & welded.
then it can be machined & all welded up.
But it is very well expensive., a casting might be the method instead.
what is the material required & how many?
get a quote as a casting vs fabrication. then decide.
Mfgenggear
Mfgenggear
http://ssldev.lincolnelectric.com/foundation/item....
Any reason for changing the process?
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
Keep in mind even with the best strategy, you may lose the first weldment due to warping.
Its is sometimes easy to underestimate how hard it is to weld something up in the correct order first time without something pulling.
Just yesterday I saw some 30mm plate in pretty small sizes turn into S hooks due to poor jig/tack up design.
Brian,
