Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I signed up to your site to get help with a problem and I am so glad I did. I found the help I needed immediately. Thanks to all who contribute to your site..."
Geography
SamSlivinski (Industrial)
17 Aug 12 8:51
I am trying to sweep a sketch around a guide that is circular, but has a "bump" in it. The bump is a segment of a larger circle concentric with the first that has two tangent curves attaching it to the smaller circle. When I select these curves as the guide NX give me some convoluted pretzel shape as the result.
Sam Slivinski
Using NX 6
Manufacturing/Aerospace
jerry1423 (Mechanical)
17 Aug 12 9:40
Can you show a picture?
17 Aug 12 12:47
No mad. I wish I could, its military though. Maybe I can creat something similar and show a picture
Sam Slivinski
Using NX 6
JohnRBaker (Mechanical)
17 Aug 12 18:11
Sorry, no picture - no help.
That being said, try creating an offset curve of your original path and use this as a second guide curve.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Helpful Member!  mmauldin (Bioengineer)
20 Aug 12 7:52
Are your section curves positioned at the end of one of the guide curves? If not, you will get a pretzel shape. See attached examples.
20 Aug 12 9:02
Thank you mmauldin! The bump was at an odd angle so my section curve had just been in the middle of the cirlce. What you said to do worked!
John, I wonder if offsetting a second guide curve will produce the same result as what mmauldin said even if the secion is not at the end of one of the guiding curves? I will have to test this
Sam Slivinski
Using NX 6
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
