Correct placement of critical dimension symbol (inspection symbol)
I have a question regarding the correct placement of critical dimension symbols (aka inspection symbols) relative to the dimension it is associated with: Is it incorrect to place this symbol between the dimension value and the dimension line that points to the feature? or does the dimension value always have to be adjacent to its dimension line. For example, if the inspection symbol is <4>, and the dimension line is on the right of a R.250 radius, would it be incorrect to have R.250 <4> -------->
(where ---------> is the dimension line)? Would the same be true for inserting a note symbol (that points to a note on the drawing)? Also, is this listed in any drafting standard?
RE: Correct placement of critical dimension symbol (inspection symbol)
I'm not aware of a national/industry standard for specifically critical dimensions, and certainly not one that goes into detail about symbol placement etc.
<http://www.eng-tips.com/search.cfm?pid=0&actio...;
Some might argue that putting this information on drawing violates the intent of ASME Y14.5M-1994 section 1.4.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
