zero objects in layer after using extract or geometry wave linker
after using associative copy-->extract in a new layer i dont see any objects added to this layer. the new object is added to layer # 1
even though layer # 100 is the work layer.
RE: zero objects in layer after using extract or geometry wave linker
What object type(s) were you 'Extracting'? Also, what version of NX are you running?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
a simple cylinder.
I'm using nx 6.
I'm sorry, but I can't duplicate the behavior that you have described using NX 6.0.5.3, per the attached example.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I can see the objects in layer 100 in your file like it should be, still when i extract another time on the same file the objects are
added to layer number 1.
I'll try to get pass that somehow thanks for the help.
