Shaft torsion at cryogenic temperatures
I cannot find any recommendations for materials being used as shafts in cryogenic conditions. Shear modulus / modulus of rigidity always appear to missing from the majority of materials I do search on.
 Can anyone recommend any material with a shear modulus greater than 87 GPa (17-4PH)?
 There appears to be a lot of information about cryogenic conditioning but very little data on the properties of material at those temperatures!
Hope someone can help.
Br
Bernard H
RE: Shaft torsion at cryogenic temperatures
For high strength at cryogenic temperatures you definitly want something from the 201 family of stainless steels. Especially for a shaft. Get cold-drawn 201. The super material is 21-6-9, but that's harder to find.
Mcguire,
 Being based in the UK I am finding it extremely difficult sourcing the 201 material such that no-one can get it for me. What suppliers have you used?
The material you select, whatever it ends up being, should have an FCC microstructure. DO NOT select materials with either a BCC or HCP microstructure. These materials are subject to the ductile to brittle transition, and will fail catastrpohically at sufficiently low temperatures.
                                          Maui
I have used ASTM A564 Grade 660 on valve stem at -120C and this is available from many UK suppliers.
