Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks for a great forum. My problem was answered just by scrolling through previously solved problems. Great service!!..."
Geography
richalves (Mechanical)
16 Aug 12 13:47
Hello all,
Someone knows if it is possible to use a deformed component resulting from a static simulation, as a STEP part?
Thanks in advance
KENAT (Mechanical)
16 Aug 12 13:50
Suggest you check out the Solid Works forum, should be able to get to it from here http://www.eng-tips.com/threadcategory.cfm?lev2=22
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Eltron (Mechanical)
16 Aug 12 13:51
The part deformation is graphical only. You can't save the file in a deformed state.
Dan
www.eltronresearch.com
Dan's Blog
16 Aug 12 16:10
Thanks Dan,
So it is not possible to deforme a part, applying forces?
I'm looking for construct a component that its final shape is achived by a oriented force.
Thanks.
Eltron (Mechanical)
17 Aug 12 8:56
OK. I did a little digging, and it looks like you actually might be able to do it. http://help.solidworks.com/2012/English/solidworks...
Dan
Dan's Blog
vpl (Nuclear)
17 Aug 12 9:04
You should check out forum1183: SolidWorks: Simulation/FEA (COSMOS). In fact there is already a question over there about a creased part that might answer your question.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Close Box
Join Eng-Tips® Today!
Join Us             Close
