Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I just want to say how much I value your site. I hope the good work keeps up there. It's really helped me..."
Geography
VWHITAKER (Civil/Environmental)
16 Aug 12 11:57
I am running an Extended Period Simulation in EPANet, where I have tank that should be filled by pumps. It seems that the pumps will only pump into the tank once it reaches it minimium level, meaning they don't fill the tank during the 12 hours they are on unless the tank is "empty." In other words the pumps only seem to be responding to the demands and EPANet doesn't put a demand at the tank unless it at the minimum level. Does anyone know if this is true and if there is a work around?
JonathanEngr (Civil/Environmental)
22 Jan 13 7:54
So I'm assuming the tank starts off at full volume, or at least above the minimum stage? Have you checked the demand within your system? Could it be that the demand is exceeding the pump delivery volume, thus requiring water to be drawn from the tank, as well? Without seeing how your system is set up it's kind-of hard to tell. Have you set up any patterns? Maybe trying some different demands and/or turning off a few pipes to drop demand might indicate whether-or-not this is the culprit.
Close Box
Join Eng-Tips® Today!
Join Us             Close
