Inlet pressure drop - lower set pressure?
I think I know the answer to this, but it is worth a try..
Is it acceptable to lower the set point to solve an inlet dP problem. Consider the following: MAWP = set = 75, oper pressure = 45, inlet dP = 5% (3.75 psi). Can I lower the set pressure to say 71 psig and meet the 3% code value?
RE: Inlet pressure drop - lower set pressure?
