Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This has been the MOST helpful forum that I have been a part of and I want to say thank you. The tips, tricks and helpful advice that you all contribute to have been lifesavers in many instances..."
Geography
Extruding a curved face along a vector, Please Help!!Helpful Member!(5)
djkatt (Mechanical)
16 Aug 12 6:55
Hi all,
Please let me know if this can be done because every time I try this I just get a sheet body rather than solid. Here is the description (Unfortunatly I cant upload due to IPR)
Say I have a solid wing shape, all I want to do is offset a square section of the wing surface along a vector by 8mm.
This is what I did, create a datum plane directly above the wing solid. Draw a sketch of the simple square. Do a divide face projecting the square onto the wing surface. Now that I have a separate surface I thought I could just extrude the edges of this surface along a vertical vector by 8mm, but as I said I just get a square 'frame' made up of sheet sufaces.
I have also tried projecting the sketch onto the suface and extuding the projected curves but just get same result.
I know I could just thicken the divided face but this extrudes along 'face normals' not along a vector.
Grateful for any help as deadline due soon!
BTW I dont have the freeform package, just standard NX if that makes a difference.
NX7.5
Cheers,
Rich
JCBCAD (Mechanical)
16 Aug 12 8:36
Like this? Use yor selection intent to pick face adges and make sure you hafve solid selected as your output option.
Cheers
Si
Best regards
Simon NX7.5.4.4 MP5 - TC 8 www.jcb.com
Helpful Member!  John2025 (Industrial)
16 Aug 12 10:23
JBCad,
That works with divide face, but if I pick the outer edges of the first extrusion, I get a sheet body without the top face. It seems like I run into this alot. Any idea why?
John
Helpful Member!(2)  JCBCAD (Mechanical)
16 Aug 12 10:38
I have done another one, is this what you mean? basically all I do is use selection intent to make sure I either pick sheet edges of face edges and then within the extrude dialog, make sure that solid is selected as the ouput. That's the only thing I can think of sorry sad
Best regards
Helpful Member!(2)  JohnRBaker (Mechanical)
16 Aug 12 10:44
If you use the 'Face Edges' option then the FACE itself is ALSO used to help define the resulting solid. However, if you simply select the edges, as if they were independent curves, since they do not form a planar section it's not possible to create a solid as there is NO way to know exactly what the shape of the 'start' and 'end' capping faces would look like if all you had were four 3D curves and no other inputs.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
djkatt (Mechanical)
16 Aug 12 10:46
Many thanks for looking at this Si.
Yes that is what I want, unfortunatly I tried it on my part and couldnt get a solid body (solid body checked on extrude).
The only main difference between your part and mine is that mine is curved in more than one plane.
I managed to recreate the unwanted effect I am getting by doing a square on a sphere.
See attached.
Now im thinking that is the limit of my NX package without the 'freeform' add on??
Cheers,
Rich
djkatt (Mechanical)
16 Aug 12 10:48
Hold on, I will look for Face edges, selected just edges before!
djkatt (Mechanical)
16 Aug 12 10:52
Brilliant! Many thanks guys! Forgot to select face edges in the drop down.
One thing Si, did you really need the projected curves? I was dividing the face directly with the sketch.
Stars all round!
16 Aug 12 11:16
Quote (djkatt)
That should have no effect whatsoever.
And the Face Edge approach works with doubly-curved surface (see attached example).
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
16 Aug 12 12:27
Ha!! Thanks guys, I always thought this was just a limitation. Now I get to show off and tell the other 2 users.
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
