NX7.5 - delete perimeter dimension from a sketch
3
A user wishes to add some new curves to an existing sketch, which is controlled by a perimeter dimension.
Does anyone know how to delete the dimension, so that he can make the edits?
Thanks, Carl
RE: NX7.5 - delete perimeter dimension from a sketch
start the dimensioning tool in the sketcher, press the first button in the toolbar,
a big dialog opens where you can find all dimensions inside the shetch, look for the perimeter dim. mark and X
Thank you very much, that's perfect!
Regards, Carl
