SAP2000 Error Reading Results
I have a large SAP2000 model with a large number of results (9GB model). I am using the AIP to extract the results from the SAP2000 database. It works fine for extracting a few results, however after running for a long period of time it returns a diologue box 'errors in recovering joint results' and then 'error in reading joint results'. Can anyone answer the following?:
1) Can anyone explain what this error is?
2) Is there a way to speed up the extraction of data, as the computer only uses one of it's four core processors during extraction?
3) Is there a way to prevent this error?
Many thanks
Many thanks
