save-as journal
save-as journal
save-as journal
Can someone help me to create a very simple journal.
I want to be able to save the displayed part (a drawing)
to a specific network folder (the same one every time)
I'll create a button so its a one touch operation.
At the moment i have to go, file-> save-as -> then browse to the folder, and then OK.
(only the drwg needs saving, not the parts below it)
I've tried creating this as a macro, or journal, but it stays tied to the part i create it in.
Help very much appreciated.glasses
RE: save-as journal
Moog2,
This works for a mapped network drive.
' hope this helps,
Joe
CODE
Option Strict On
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim thepath As String = "z:\"
Dim PartExt As String = ".prt"
Dim displayPart As Part = theSession.Parts.Display
Dim partSaveStatus1 As PartSaveStatus
partSaveStatus1 = workPart.SaveAs(thePath+displayPart.Leaf+PartExt)
partSaveStatus1.Dispose()
End Sub
End Module
RE: save-as journal
That works like a charm, thanks very much for your help Joe medal
RE: save-as journal
bigcheeksDOH........ I spoke too soon, i tried it out at work and everything worked fine, however this has to work at an off-site location, and the destination folder, is on an external hard drive connected locally to a stand alone PC, can someone help adjust the journal to work on a local drive?, thanks
RE: save-as journal
Moog2,
This works (for me) to an external disk attached to the local computer (I:\) (edit as needed).
HTH, Joe
CODE
Option Strict On
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim thepath As String = "i:\"
Try
Catch  ex As Exception
End Try
End Sub
End Module
RE: save-as journal
shadeshappyyep, that works just fine, thanks again for your help
