In need of a new PDM system supporting SolidWorks
My company does not want to upgrade to EPDM; but they want to create a vaulting system which will index all files.
I have been researching programs such as DBWorks, Conisio…
I’m looking for comparable programs, or any extra info would be appreciated.
Statement below is info from my VAR about SolidWorks Explorer and our 64 bit’s
~As is mentioned in many Microsoft forums, this is a Microsoft Windows limitation. Mapped, network locations cannot be indexed by Windows Search on Windows Vista x64 or Windows 7 x64, therefore they cannot be added to SolidWorks Explorer's search paths list. To workaround this limitation, you can make the files stored in the mapped, network location available offline. Files that are made available offline can be indexed by Windows Search and can therefore be added to the search files list since they will be stored locally. Search the Windows Help for "sync offline files" for more information on how to setup offline files.
476452 - Cannot enable Indexing service search for Workgroup PDM on Windows Server 2008 64-bit, Windows Server 2008 R2 64-bit, Vista 64-bit and Windows 7 64-bit operating systems – open - Until this is achieved we cannot consider Workgroup as being fully supported on Windows Server 2008. Please see KB S-054407 for manual methods to enable Indexing for the Operating systems in question.
For SPR 476452 there will not be a Service Pack or future version delivered solution available for this limitation. However, SolidWorks Development and Technical Support have developed the attached instructions for a workaround which will configure these operating systems to enable the Indexing Service to work in concert with SolidWorks Workgroup PDM Search. These instructions do require changes to be made in the Window registry which should be done with caution and only by individuals comfortable with making registry edits~
Thank you,
SAF
