Hard to find valve, need help!
Looking for a 3-way ball valve, 3/4" FNPT end connections, L-port configuration. The kicker, process is 700 Degrees F & 3000psi. Media is Bio Fuels. Anybody know of a manufacturer? Will need metal seats.
Thanks in advanced,
Thanks in advanced,
RE: Hard to find valve, need help!
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
Stanier, Thanks, I'll give them a call.
Much appreciate both inputs!!
Cameron (TBV) or perhaps Flowserve (Noble Alloy Valve) might be able to make you a barstock valve that suits your needs, as long as you're realistic about the seal-tightness you can expect out of the metal seats. Two two-ways would be way easier to find and a more practical fit to your process conditions: link the handles if you must. But forget about the NPT end connections. At least weld on some Swagelok fittings or something!
