NX7.5 - Breaks in dimension extension lines
What are the (design) rules that should be followed when we create breaks in dimension extension line?
1.Breaks created between 2 dimension lines that intersect each other?
2.Breaks created between one dimension line and other objects?
Thanks!
Thanks!
RE: NX7.5 - Breaks in dimension extension lines
http://www.eng-tips.com/viewthread.cfm?qid=215427
As far as "rules" go that should be followed . . .
There really isn't any such thing in any drafting standard.
I know how to create gaps.
I was interested in the rule that manage this operation.
Regards!
If you add a gap and want to remove it some other time - What you will need to do is turn that extension line "off" and then back "on".
Best regards
Simon NX7.5.4.4 MP5 - TC 8 www.jcb.com
You can easily change the size of the gap, by changing its length.
Where it says Define Symbol Size By, you need to change that to Length and Height, and then change the length value
