Questions about machining tolerance and time
Hi i am trying to figure out what cutting machines can do in tolerance and time, so that i get a better felling for the cost and to sort out some confusion
1.In an CNC machine are there any difference between the output tolerance between making a surface of 500x500 flat and the drilling of four holes 500x500 from each outer.
2. If i am going to make a surface of 1000x1000 mm^2 flat, who much in time does in vary between the following planarity tolerances, 1 0,1 0,01 in a feature control frame
Thank you in advance
RE: Questions about machining tolerance and time
On the first question, yes I'd expect a significant time different between machining a surface flat over 500*500mm and drilling holes in each corner. Of course you don't say how flat, what surface finish, how thick material/how deep holes, what size holes, what material etc.
On the second question, you may find that for the tighter tolerances you may need to go to a different process. Again you don't give material information, surface finish etc.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
It also may be that desired surface roughness will actually affect your cycle time more than tolerance, because it will require slower feed rate.
Just a thought.
For general machining tips there have been a few posts over time, I suggest a site search may turn up something. I got these results as the first few hits using site search.
thread404-163892: Machining Parts - What school didn't teach me?!
thread404-278305: More Machining/Design Tips
thread1103-197339: Machining tips
http://www.eng-tips.com/viewthread.cfm?qid=284781
There have been others, some relating to specific materials/processes such as sheet metal but my search kung-fu is week today for some reason!
For drilling, you will be moving the head to 4 points, so the distance calculation is easy.
For milling the surface, you need to account for the size of the milling cutter. In order to do 500x500, you would need a 250 diameter cuter to do it in 2 passes, but the travel distance is only 250 for the stepover, instead of the 500 for the hole distance stepover.
As Kenat pointed out, drilling holes use a rapid feed between points and milling speed has other factors to consider: material, cutter material, rigidity of the workpiece, surface finish, etc.
Ben Loosli
Doh.
More realistically/typically if using say a 25mm cutter then yeah you're looking at 20 or so passes simplistically so 5X the traveled distance for just the corner drilling.
Realistically, any cutter over 100-125mm in diameter is hard to load in a CNC machine with tool changer. A 500mm+ diameter cutter would require manual tool change.
Ben Loosli
This is not really a dimension and tolerance question. You would be better off asking this in forum281: Machines & Machining engineering.
JHG
