Parts list questions
When there are parts in a parts list which I don't want to see, I just delete them in the list. But is there a nicer way to do this. I mean, sometimes I have loads of parts in the list of which some of them I don't want to see. I would like to exclude them from the parts list whem building the assembly in the modeling application.
Another question. When I delete the parts list I can not place it again in the same style as it was in the drawing template. Where are the settings of the parts list stored?
Regards, Michel
Regards, Michel
I use NX7.5.4.4
HP Z600 Intel Xeon E5520 2.27GHz Dual
9GB Memory
Windows 7, 64-bit
Groeten, Michel
www.kvi.nl A leading Dutch institute in atomic and subatomic physics
RE: Parts list questions
PLIST_IGNORE_MEMBER value= YES
http://www.eng-tips.com/viewthread.cfm?qid=298393
Maybe this thread will help you figure out how to save your parts list configuration:
http://www.eng-tips.com/viewthread.cfm?qid=314829
I found out that you can do it at dwg level or part level. If done in part level you will not see it in any assembly BOM anymore, I guess.
But I also found the command "PLIST_IGNORE_SUBASSEMBLY". I understand that a whole subassy can be suppressed in the BOM. But this does not work with me. It has the same result as "PLIST_IGNORE_MEMBER".
Regards, Michel
I use NX7.5.4.4
9GB Memory
Windows 7, 64-bit
Groeten, Michel
I use NX7.5.4.4
9GB Memory
Windows 7, 64-bit
Groeten, Michel
http://www.eng-tips.com/viewthread.cfm?qid=270748
You may want to read John Baker's reply in this thread pertaining to attributes at differnt levels:
