Corrosion protection for Maraging steel
I am looking for corrosion protection for C300 and C250 maraging steel. Must pass high humidity, salt water environment.
RE: Corrosion protection for Maraging steel
Cadmium coatings (vapor deposition instead of electroplating) are used for a variety of aerospace applications. If you can provide some additional details, we can help narrow down the candidates.
1. zinc phosphate + epoxy electrocoat (25 micron thickness) = 500 to 1000 hours. Higher film build will give up to 2000 hours.
2. Magni or Dacromet = 500 to 1000 hours, depending on film build and exact formulation.
3. Cadmium (I meant vacuum deposition not vapor) = 96 hours at a typical thickness of 12 microns.
