Angeled hole dimension leader
How can I manage to change the hole dimension leader from straight to an angeled one. Like the one you see in all the symbols. See attachement.
Regards, Michel
Regards, Michel
I use NX7.5.4.4
HP Z600 Intel Xeon E5520 2.27GHz Dual
9GB Memory
Windows 7, 64-bit
Groeten, Michel
www.kvi.nl A leading Dutch institute in atomic and subatomic physics
RE: Angeled hole dimension leader
I use NX7.5.4.4
9GB Memory
Windows 7, 64-bit
Groeten, Michel
I am using NX 6. Your version may be a bit diffirent but should be similar.
I use NX7.5.4.4
9GB Memory
Windows 7, 64-bit
Groeten, Michel
I use NX7.5.4.4
9GB Memory
Windows 7, 64-bit
Groeten, Michel
With the second "problem" you had go back to the style menu and click on the line/arrow tab and chance the leader side from left to right.
I use NX7.5.4.4
9GB Memory
Windows 7, 64-bit
Groeten, Michel
Sam Slivinski
Using NX 6
Manufacturing/Aerospace
I use NX7.5.4.4
9GB Memory
Windows 7, 64-bit
Groeten, Michel
CATIA V5 R20
PC-DMIS 2011 MR1
Sam Slivinski
Using NX 6
I use NX7.5.4.4
9GB Memory
Windows 7, 64-bit
Groeten, Michel
See attached image.
The problem originates , i think , due to that we europeeans have a different standard/ practice on this type of dimension compared to the American practice. - For some reason ( according to ISO) radial / diameter dimensions like these should have the text horizontally oriented whilst at the same time other dimensions where the dimension line is non-horisontal the text should follow the dim line.
Maybe you are right with the standard issue. But in my case I find it just nicer to have that text horizontal.
I use NX7.5.4.4
9GB Memory
Windows 7, 64-bit
Groeten, Michel
