GFRP Rebar in Coastal Structures
I've been designing a lot of structures lately that are right along the coastline. Retaining walls, soil nail walls, box culverts, etc... Since they are getting constantly battered with waves, we have been using stainless steel and GFRP rebar. The stainless steel is used mainly for the flexural reinforcement and the GFRP more for temperature and shrinkage. I do, however, use some GFRP bars in the less critical flexural zones such as in the shear key or the toe of the footing. Since the glass bars do not behave the same as a typical isotropic alloy, what "yield strength" would you use in the design of the bars? I keep reading that the ultimate strength is much higher than standard steel ~ 110ksi. But I'm not sure if the glass bar experiences a transition from the elastic to inelastic range at a much lower value. I have been using 60ksi as this is what has been recommended to me. Thanks.
RE: GFRP Rebar in Coastal Structures
You are correct in that the failure is more much brittle than regular rebars and this should considered accordingly in design.
