ferrous Chloride use for waste water oder control
Does anybody have any experience in odor treatment using ferrous chloride at lift stations? We first started using Calcium Nitrate, and it work very well, but we started looking for cheaper and, change to ferrous sulfide, we had some luck with it but it would corrode stainless steel and was not as strong as the first meaning we had to use twice as much, we are getting away from it because it ate the bearings out of a grinder.
We are going to change to the chemical ferrous chloride, and were needing to know if our current setup we used on past chemicals is going to work with the chemical. We store our chemical in neoprene tanks and use PVC piping from the tank to our wet wells, will the ferrous chloride corrode the tank and pipes, and will corrode the bearings in our grinders. Are there any other problems with this chemical that we should know about?
Any suggestions are greatly appreciated.
RE: ferrous Chloride use for waste water oder control
I have a bit of experience in material selection for handling ferrous chloride. The Neoprene lined tanks and PVC piping will be fine (at ambient temperatures) for handling the ferrous chloride. However, keep in mind that this chemical is brutal on most metals, and much more agressive than even the ferrous sulfide that you mentioned. What are the material of construction of your bearings?
glennpan
Mike Bensema
www.dutchmenservices.com
As well as Ferrous Chloride, Hydrogen Peroxide and a number of proprietary products are used here in the UK.
Magnesium Hydroxide is actually quite a bit more expensive than ferrous choride in my experience,on the basis of quantity required for aour control.
Seán Moran
www.expertise-limited.co.uk
Mike Bensema
The running costs are favourable with other methods and no dangerous substances are used. The result is significant asset protection, proven odour neutralisation and low cost start up infrastructure.
For more information please contact karl@eco-safe.com.au
It has a skimming action at the end of each pumping cycle, allowing all floatables (oils, fats & scums) to be entrained into the pump & thus pumped away.
It is the fats & oils sitting on the liquids surface which usually causes the odours.
Pre-Rostal systems have virtually self cleaning sumps.
I have seen Ferrous Chloride in action & it ate through 316 SS pump lifting chains (you can imagine what it did to the submersible pump !!). Not sure though if the sewer maintenance engineers didn't get their dosage a bit too high though !!
Take care,
Berko
