where is in aci rebar splicing in columns should not all be the same location?
i rarely do concrete column but i remember there is this requirement. i want to check if this also applicable for walls and mat footings.
RE: where is in aci rebar splicing in columns should not all be the same location?
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
my draftsman alternately spliced my mat footing rebar even though i didnt say so. before i tell him it aint necessary, i want to be sure.
I think the column requirement you are remembering may be for long columns, e.g. three storeys high unsupported where single length bars are not available.
