Dear members What is the related
Dear members
What is the related standard for center to face dimension of angle globe valves?
regards
Arash
regards
Arash
RE: Dear members What is the related
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
As xnuke explains, most international valve standards will now includse this as a standard. Apart from this, you can quite often come across misfits when replacing old valves. Reason: older might be nonstandard (older 'factory' standards or practise).
Advice: for new constructions: check relevant standard and desccribe.
Replacing: check relevant standard. If replacing non-standardized, use new standard and rebuild. Mostly newer are shorter pattern and extension rings etc. can be utilized to give full length.
As you mentioned ISA 75.08 is about globe-style angle control valves.
How about manual angle valves?
