Publication. Does it require special licensing?
I am interested in learning about and using publication. Reading through the CATIA documentation, it says to select "Tools > Publication" to get started.
Is there a special license required? There is no publication entry in my tools menu either in Part design, or assembly design.
I'm using V5 R20
I hope this isn't the stupidest question on the forum.
Nick
Light structural commercial aircraft parts
PCDMIS 4.3 CAD++, CATIA V5 R20, NX6
APM Consortium Inc.
Cambridge Ontario, Canada
RE: Publication. Does it require special licensing?
I think you need an ASD license for the Assembly Design workbench -- Tools - Publication. I verified with a colleague as he has an AS1 license. The Tools - Options - General - License tab will give you a run down of the modules you have. I see from his license he could be getting the publications from either CCV (core/cavity separation) or FMP (Functional Molded Part). His other modules include GS1 (Generative Shape Design 1), HA1 (Healing Assistant 1), and a list of other 1 level products.
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
Hmmm. Our only license is "CAC" which allows for Part design, Assembly design, and Drafting. I suppose I do not have publication abilities then.
Nick
APM Consortium Inc.
Nick, we have it with our MD2 license, and use publications extensively with the Part Design workbench.
It's especially useful when replacing linked objects!
