Annoying suspension geometry questions
Hi Everyone. Firstly let me apologise for asking the same questions as many others will have done before me. I'm struggling a bit with lack of experience.
I'm designing the suspension for a light weight sports car:
700kg
300 bhp
front engine
rear drive
twin wishbone front
twin wishbone rear
14" wheels
It will be used both on the road and track but never for racing. I intend to use a performance (road legal track tire) such as Toyo R888/Yokohama A048 etc..
It will be possible to use a slightly wider tire on the rear (but the wheels will have the same rim width)
I have design freedom for all inboard suspension points front and rear, and so roll centre positions etc.
I have a CAD assembly of a front and rear corner and a Suspension kinematic model in WinGeo.
Where I'm struggling is to decide on inboard suspension positions without tire data. I understand that the influence of springs bars and tires are far more influential than subtle changes in my geometry, I'm just trying to make sure I have a good starting point. For now I've just included roll and ride iterations below:
The front suspension is a work in progress but at present gives very similar results to the rear in terms of camber gain and roll centre migration (ignoring the affect of caster and steer angle for now)
Shot at 2012-08-14
Questions:
Does this look sensible?
Should I try and decrease the positive camber of the outside tyre at full roll?
How much anti squat should I aim for? (at the moment there is none, I have a SAE paper suggesting 80-90% for a passenger car... )
How much roll axis inclination is sensible, at present my static roll centres are:
front Z - 38
rear Z - 50
I could probably get the front on the ground with some more work.
Thanks all for your help. I'd love to be about to move on from this stage soon and start building, just want to avoid dropping a clanger..
tom
700kg
300 bhp
front engine
rear drive
twin wishbone front
twin wishbone rear
14" wheels
Shot at 2012-08-14
Questions:
front Z - 38
rear Z - 50
tom
RE: Annoying suspension geometry questions
Cheers
Greg Locock
I really don't, but is it actually possible to prevent that on the rear without using a lot of static camber? (this is my first suspension design, still not totally clear what is achievable)
I read at some point that ball park camber gain for a performance car is 0.6-0.9 deg/inch bump, which I'm achieving.
Interestingly I just found this data for the rear of a Caterham SV
Shot at 2012-08-14
Their camber change per degree of roll is higher than mine!
Shot at 2012-08-14
Cheers
Greg Locock
I don't see anything especially alarming there.
I see no point in dropping front roll centre to ground level, it should either be below ground level and stay there or above, and stay there.
Cheers
Greg Locock
I tweaked a little more and the rear RC is now ~60 with front ~38.
Whilst I have your attention, can you comment on anti squat? I'd like some, perhaps 15% but this has introduced significant bump steer. Is the game now to move the trackrod out of plane with the lower wishbone, and use its arc to try and cancel the bump steer?
Cheers
Greg Locock
I would not be enthusiastic about anti-dive or anti squat on a race car.
