Qualified 2 welder using 1 test coupon (AWS)
All,
Can I qualified the 2 welder using 1 test coupon only according to AWS D1.1? Which clause i should refer to? is it the trade designation equal to trade name?
RE: Qualified 2 welder using 1 test coupon (AWS)
Which of the two welders actually did all of the welding on the one coupon?
(Was the second a fire watch? The test coupon is for confirming and testing the actual welding performed under controlled conditions. How can two welders do one coupon?)
newbie engineer
Subject: Qualifying Two Welders on One Joint for Pipe
Code Edition: D1.1:2006
Code Provision: 4.30.3.1 and 4.19.1.1
AWS Log: D1.1-06-I20
Inquiry: Based on 4.30.3.1, is it allowed to qualify two welders on the same joint, each of them welding half pipe circumference, from top center to bottom center (either uphill or downhill progression)?
Response: No.
Best regards - Al
newbie engineer
If you have a qualified WPS for GTAW / FCAW then it is fine to use GTAW (Welder A)and FCAW (Welder B),
Kiwi
