Perform Analysis with Journal
I want to check a dynamic assembly with the clearance check.
I use the journal with VB to modify some expression in a loop to run trough the diffrent positions of the assembly. For each position i want to run the Assembly clearance check.
How can i run the "Perform Analysis" in the Journal ?
Unfortunately it is not recorded by the journaling....
thanks
Leon
thanks
Leon
RE: Perform Analysis with Journal
Dim partTag As NXOpen.Tag
Dim Clearance1 As NXOpen.UF.UFClear
' Perform Analysis of Clearance Check
Clearance1.DoClearanceAnalysis(partTag)
but i get the message that Clearance1 is used wihrouth having a value..... what i need to define furher ?
best regards
leon
www.nxjournaling.com
it is already solved. Part of thge code is:
' Collissioncheck Perform Analysis
Try
theUfSession.Clear.FindDataset(workPart.Tag, toFind, fDataset)
Catch ex As Exception
fDataset = Tag.Null
End Try
If (fDataset <> Tag.Null) Then
Dim fdsName As String = ""
theUfSession.Clear.AskDatasetName(fDataset, fdsName)
' writer.WriteLine("Running in Find Mode: " + fdsName)
Try 'Funktion hat keinen Rückgabewerte
theUfSession.Clear.DoClearanceAnalysis(fDataset)
theUfSession.Clear.AskResults(fDataset, summary)
'theUfSession.Ui.DisplayMessage("" + summary.new_n_hard.ToString(), 1)
' If Collission found write to report
ClearanceResult=summary.new_n_hard.ToString()
If ClearanceResult <>"0" then
Textline= "Circumference Position:;" & counter1 &"°"& ";Tilting Position:;" & counter2 &"°;"& ClearanceResult & "; Hard Collissions found" & vbcrlf
My.Computer.FileSystem.WriteAllText(filePath, Textline, True)
End If
theUfSession.Ui.DisplayMessage("Error detected",1)
End Try
Else
theUfSession.Ui.DisplayMessage("Dataset " + toFind + " not found",1)
End If
Main Problem was, that the finddataset methode does not find the clearance set if the clearnce set is set to "component". If it is set to "body" it works.....already acknowldged by GTAC.
best regards
Leon
