Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...It is good to know that there are groups such as this willing to share knowledge in this money driven economy..."
Geography
RFreund (Structural)
13 Aug 12 21:38
Most attics around here (Midwest USA) are insulated with blown cellulose (I believe) insulation. Has anyone come across an average density or average thickness/weight used in homes?
Or how about the insulation that has a 'paper' side and the other-side has the fiberglass insulation.
Thanks!
EIT
www.HowToEngineer.com
JAE (Structural)
13 Aug 12 22:08
Pretty light - I'd only use 2 psf or so. That might be heavy.
Ron (Structural)
13 Aug 12 23:04
JAE is right. It is about 0.1 to 0.2 psf per inch of thickness, as long as it hasn't compressed with time.
Fiberglass batt insulation is about 1/2 those values.
14 Aug 12 8:21
Thanks guys.
EIT
MiketheEngineer (Structural)
14 Aug 12 10:51
I usually just ignore it IF I spec 10 psf for ceiling load which would include drywall, insulation, lights, etc. That is typical around here.....
msquared48 (Structural)
18 Aug 12 0:40
.3 psf per inch of thickness is what I use.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
29 Aug 12 13:10
Call the mfg
MikeHalloran (Mechanical)
7 Sep 12 12:20
Blown cellulose, layered at least as deep as the rafters as is usual in SoFla, gets pretty heavy when it gets wet, like after a hurricane has peeled away your shingles. Fiberglass doesn't absorb and hold water to the same extent.
Maybe that's not a legitimate design condition, but it does happen.
Mike Halloran
Pembroke Pines, FL, USA
7 Sep 12 15:04
I think you guys in Florida need to design airtight houses so that just before a Hurricane hits, you can suck all the air out and keep the shingles tight to the roof membrane. Just a thought...
Mike McCann
MMC Engineering
7 Sep 12 22:19
As part of an ad-hoc repair team after Andrew, I inspected a condo's roof where the membrane had been lifted, mostly intact, a couple of feet above its plywood support, and settled down, mostly intact but with a few leaky wrinkles.
After Wilma, I intend to ride out future hurricanes in some other state, say Idaho.
Mike Halloran
Close Box
Join Eng-Tips® Today!
Join Us             Close
