angeled ordinate dimension
RE: angeled ordinate dimension
since nx4 you are able to do this.
activate the ordinate deimension set rmb on the defining ordenate axis, (re)define axis / direction
Thank you. It is easier then I thought.
I use NX7.5.4.4
HP Z600 Intel Xeon E5520 2.27GHz Dual
9GB Memory
Windows 7, 64-bit
Groeten, Michel
www.kvi.nl A leading Dutch institute in atomic and subatomic physics
