Modification of plan 53 C to plan 52
Dear All,
We are currently having a problem on the said seal flush plan. Currently the installed plan for the 4 pumps is plan 53 C. However, our licensure learned that applying plan 53 C once the seal wear will contaminate the process fluid (ethylene). The recommended solution now is change the plan from 53 C (barrier fluid) to 52 (buffer fluid). Operating temp is -36.3 deg C. Do you have any experience for this low temp application? thanks in advance. We are in construction process and next year will be the commissioning of these pumps.
RE: Modification of plan 53 C to plan 52
