LV grid transients - an encore
More than four years ago, I needed to know about real world transients on LV grids. See http://www.eng-tips.com/viewthread.cfm?qid=207168
I am now trying to understand what IEC 60 439-1 actually says. My interpretation is here http://www.gke.org/pub/files/IEC%2060%20439-1%20tr...
But that is a lot more than I or anyone else seems to have encountered IRL. Does anyone have any new experiences? Any recordings of "Killer Transients"?
Gunnar Englund
www.gke.org
RE: LV grid transients - an encore
No new data?
Gunnar Englund
www.gke.org
Invisible? Am I?
Gunnar Englund
www.gke.org
FWIW, here in Australia we manufacture electrical safety devices for mining environments and the standards we adhere to require withstanding 75%-120% of the nominal LV line voltage continuously, and 50% for 2 seconds. The only transients considered are dielectric tests - ie. voltage to earth.
For example, here is the LV part of the table for test voltages as required by AS/NZS 2081. It shows the maximum voltage of the power circuit, the power frequency voltage withstand level (1) and lightning impulse voltage withstand level (2). Values for U(m) are in V and for (1) and (2) are in kV.
|U(m)| (1) | (2) |
| 275 | 2.5 | N/A|
| 450 | 3.0 | N/A|
|1200| 4.0 | 10 |
The power frequency voltage withstand is for 1 minute and the lightning impulse is a 1.2/50us wavefront.
But as far as transients phase to phase go, I haven't heard anything about values greater than 120% nominal. But then again, it's not really my field.
Thanks, Liteyear!
Your answer is in line with our experience. I am beginning to doubt the validity of the IEC 60 439-1 standard. Where, and under what circumstances can such a transient occur?
Gunnar Englund
www.gke.org
