meter Burned
meter Burned
i have big problem when i connect electrical meter on machine after one hour i found the over heating on meter and after little period the meter burned ( electroincs bord) also i connected over 90 meter in different machines and this case occure in the machines which connect in the same transformer
RE: meter Burned
Bill
"Why not the best?"
Jimmy Carter
RE: meter Burned
RE: meter Burned
RE: meter Burned
Also, what were the initial readings on the machine where damage resulted compared to the other machines?
[ponder]
