High Temperature corrosion
[smile]Hi all;
I have difficuties in finding information to solve following practical situation.
How to calculate corrosion rate of AC HK alloy in air at 1600 F running for a 100 hrs test period?
I would appreciated any help.
RE: High Temperature corrosion
Thanks for your replies. I believe AC HK alloy is HK40 which is Cr/Ni high temperature resistance alloy. It has been using reformer tubes in Hydrogen furnaces in refineries. The medium is AIR.
RELATED SPECIFICATIONS
ASTM: A 297 (HK); A 351(HK30 and HK40); A 567 (HK40 and HK50 - specification discontinued in 1987); A608
(HK30 and HK40)
Nearest wrought grade: AISI 310.
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
If it is real world, find out what the composition of the air axctually is.
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
Thomas Eun
