Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks! Awesome group. I put out a simple question in the access/vba forum that I couldn't find answered on technet or anywhere else on the web and it was answered the same day!!..."
Geography
jeffking (Marine/Ocean)
11 Aug 12 17:38
In calculating the cross curves of stability what happens when the deck edge goes under water? Is the righting arm calculated as if the vessel simply rotates about the center line at various angles? For example, a barge at 10 - 20 degrees will have the deck edge under water. Yet the cross curves of stability are calculated out to 90 degrees. Or is the new buoyancy equilibrium found then the righting arm? I have a few good naval architecture references as well as several from the internet but this point is not clear to me.
thanks, Jeff
GregLocock (Automotive)
12 Aug 12 20:13
Yes you have to recalculate the equilibrium each time, if you are serious about this calculation.
Cheers
Greg Locock
13 Aug 12 9:31
thanks Greg
Close Box
Join Eng-Tips® Today!
Join Us             Close
