Move an embedded chart on a worksheet to a chart sheet with VBA
Does anyone know how to move an embedded chartObject from a worksheet to a separate chartsheet with VBA. Manually I would just right click and select move to new sheet but I can't find an equivalent VBA command.
Since it is a chartObject, I can't use Charts.move. Chart.add will create a new chartsheet, but I can't figure out how to move the chart from Sheet1 over to the newly create chartsheet.
RE: Move an embedded chart on a worksheet to a chart sheet with VBA
This will work if the chart is active. If not, replace "ActiveChart" with the name of the chart object.
ActiveChart.Location Where:=xlLocationAsNewSheet
Thanks, both of those work great.
