Fiberglass GS&T Long Part
I have a part .138"thk X 9.0"W X 438" L made of Fiberglass composite mat'l. The supplier is sending parts in with vertical waves over the Horiz length of the part. If I put a FLATNESS tolerance on this part how would this look in the control frame? Should datum points be place along the part? If so, how would this Control Frame look.
+-.025 over 36" sections? Exterior part that requires aesthetic appearance to be minimal.
