Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This site is truly a marvel. Without a doubt the most comprehensive, friendly and just plain useful resource of its kind..."
Geography
Forming aluminum while at annealing temperature
rctong (Mechanical)
10 Aug 12 13:05
What happens when you try to deform aluminum while its at its annealing temperature? Are you able to form it without concern to fracture since the grains are recrystallizing?
R
berkshire (Aeronautics)
10 Aug 12 13:43
See if you can get a used copy of Forming Alcoa Aluminum.
http://www.amazon.com/s/ref=nb_sb_noss/182-7569618...
They are available for between 15 and 45 dollars used , they are no longer in print.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
swall (Materials)
10 Aug 12 14:45
By hot forming aluminum at the annealing temperature, you are basically forging. The temperature for forging and annealing of most aluminum alloys are in the same range, so I would not anticipate any issues. You may get some grain growth and recrystallization, like you do in forgings.
KENAT (Mechanical)
14 Aug 12 15:16
At slightly lower temperatures you may be able to use super plastc forming, plent of web results for that.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Close Box
Join Eng-Tips® Today!
Join Us             Close
