Null tag not allowed: Changing the color of composite curves within the same journal file using VB
I am writing a journal file which is designed to extract a composite curve from a selected edge (or group of edges), assign it some attributes, and also give it a bright color so the user knows they've already done the process on that edge, after the process. Everythiing runs flawlessly, with the exception of the color change.
The error I'm getting is this: "NXOpen.NXException: Null tag not allowed"
at NXOpen.DisplayModification.Apply(DisplayableObject[] objects)
at [tool name].ColorChange(CompositeCurve_curve3) in [file location]:line 625
at [tool name].apply_cb() in [file location]:line 277
Line 277 is where the function is called. Line 625 is where my issue is. Here's mycode:
ColorChange(compCurve)
Public Function ColorChange(ByRef curve3 As Features.CompositeCurve) ', ByRef WeldName As String)
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim curves1() As Curve
curves1 = GetCurvesOfCompositeCurve(curve3) 'this extracts all the curve ibjects from the composite curve feature as an array of curves
Dim dispObjs(curves1.Length - 1) As DisplayableObject
For i As Integer = 0 To curves1.Length - 1
dispObjs(i) = CType(curves1(i), DisplayableObject)
Next
Dim displayModification1 As DisplayModification
displayModification1 = theSession.DisplayManager.NewDisplayModification()
displayModification1.NewColor = 3
displayModification1.Apply(dispObjs) 'this is line 625
displayModification1.Dispose()
End Function
I'd really appreciate any advice anyone can offer, I have almost no experience with programming and this specific function has given me lots of grief.
Please let me know if any more information.
Thank you,
Peter
RE: Null tag not allowed: Changing the color of composite curves within the same journal file using VB
I am using NX 7.5, if that helps.
Below is an easier, slightly less efficient alternative, it involves changing the color property of each curve individually.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.Features
Module Module1
    Sub Main()
        Dim theUI As UI = UI.GetUI()
        Dim selectedFeatures As Feature()
        Dim compositestring As String = "Select composite curves"
        Dim curves() As NXObject
        Dim curveEntity As Curve
 'Dim curveType As String
        Dim totalLength As Double
        selectedFeatures = selectFeatures(compositestring)
        For Each compositecurve1 As Features.CompositeCurve In selectedFeatures
            curves = compositecurve1.GetEntities
            For i As Integer = 0 To curves.Length - 1
 'curveType = curves(i).GetType().ToString()
                curveEntity = curves(i)
                curveEntity.Color = 3
                curveEntity.RedisplayObject()
 'msgbox(curveType)
                totalLength = totalLength + curveEntity.GetLength()
            Next
        Next
        MsgBox("Total Length: " & totalLength)
    End Sub
    Function selectFeatures(ByVal prompt As String) As Features.Feature()
        selectFeatures = Nothing
        theUI.SelectionManager.SelectFeatures(prompt, Selection.SelectionFeatureType.Browsable, selectFeatures)
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
 'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
www.nxjournaling.com
Cowski,
Thanks you very much for responding...can't tell you how annoying it was to have an automation journal work great in almost every regard but look ugly simply because I couldn't change some colors. Fortunately I did figure this out using precisely that solution a week or two ago. Here's the code I settled on:
CODE -->
Public Function ColorChange(ByRef curve3 As Features.CompositeCurve) 'changes the color of a comp-curve
        curves1 = GetCurvesOfCompositeCurve(curve3) 'gets curve objects from the composite curve feature
        displayModification1.NewColor = 6 'sets the color of the lines to yellow
        Dim objArray(0) As DisplayableObject
        For Each cu As Curve In curves1 'for each curve,
            Try
                objArray(0) = cu 'this makes the curve a displayable object
                displayModification1.Apply(objArray) 'and this turns that object yellow
            Catch ex As Exception
            End Try
        Next
    End Function 'changes the color of a composite curve
I was under the impression that using the ".color" method I would have to regenerate all my work to display the change, so the ".redisplayobject()" is a good solution and great to know about.
Thanks again,
Peter
