Soft starting a Single Phase Induction motor.
The voltage flicker is significant when I start my single phase capacitor split motor. I want to use a soft starter on the motor, yet I fear that the auxiliary components or starting components will not be able to handle the applied voltage for a prolonged period of time and overheat. Does anyone have experience with soft starting single phase motors?
RE: Soft starting a Single Phase Induction motor.
If you are having severe voltage drop on startup of a small single p\hase motor, it's much more likely that you have an improperly sized circuit somewhere in the mix. Find and fix that problem before you chase it with hardware.
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
If you really have power limitations then you might be better served by using a VFD as a phase converter and installing a 3-phase motor.
Are there other ways to soft start a single phase motor?
www.fluxdrive.com
Walt
