Display/Selection
Display/Selection
Display/Selection
Does anyone have a macro to toggle display/selections or perhaps I missed and icon? I usually want "select hidden edges" off but sometimes I need to either select a hidden line in wireframe or in shaded mode. Attached picture to better explain what I want to toggle.
Certified SolidWorks Associate
SW2009 X64 SP 1.0
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
RE: Display/Selection
You can assign a keyboard shortcut for all the display types. Look under the Customize > Keyboard > View section.
Sorry, I looked must have missed it.
SW2009 X64 SP 5.1
Dell Precision T5500
Nvidia Quadro 4000
Xeon 2.27GHz Quad Core, 6GB RAM
XP Pro X64 SP2.0
Sorry again. I don't want to toggle the display type but the selection type. When in wireframe I want to able to toggle the ability to select hidden lines or not same when in shaded mode.
SW2009 X64 SP 5.1
Nvidia Quadro 4000
XP Pro X64 SP2.0
CODE --> vba
Sub ToggleSelInWireframe()
Dim swApp As SldWorks.SldWorks
Set swApp = Application.SldWorks
swApp.SetUserPreferenceToggle swEdgesHiddenEdgeSelectionInWireframe, _
    Not CBool(swApp.GetUserPreferenceToggle(swEdgesHiddenEdgeSelectionInWireframe) + 0)
End Sub
Sub ToggleSelInShaded()
swApp.SetUserPreferenceToggle swEdgesHiddenEdgeSelectionInHLR, _
    Not CBool(swApp.GetUserPreferenceToggle(swEdgesHiddenEdgeSelectionInHLR) + 0)
End Sub
-handleman, CSWP (The new, easy test)
Wow, my solution and Deepak's were posted at the exact same time (down to the resolution of the measuring device).
Haa that's funny.
SW2009 X64 SP 5.1
Nvidia Quadro 4000
XP Pro X64 SP2.0
