Feedmill Cooler
Feedmill Cooler
Hello everyone
I would like to ask for help regarding a cooler whose purpose it to cool down the animal feed from 75 C to 35 C. The cooler has 2 exhaust fan
Cooler machine formula to use
〖(M〗_c)(〖Cp〗_c)(∆T)=(V)(ρ_a)(A_c)(〖Cp〗_a)(∆T_a)
M_c = mass flowrate of corn
Cp_c = specific heat of corn
V= velocity of input air in cooler
P_a = density of air
A_c= area of input duct
Above is the current formula that we would be using in order to determine the right inflow of animal feeds. We would like to find the right amount of inflow of animal feeds in order to make the process faster. I would like to ask if the formula has everything that we would be needed to consider.
Thanks in advance
Thanks in advance
RE: Feedmill Cooler
What is the cooling process, is this a direct contact air system of the feed with the air?
RE: Feedmill Cooler
RE: Feedmill Cooler
If it is you should be able to vary the speed of the belt and check and adjust the leaving temperature of the pellets .
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
RE: Feedmill Cooler
RE: Feedmill Cooler
RE: Feedmill Cooler
You have what you need to calculate the corn flow. The right side of your equation will give the overall heat load. From this and the corn specific heat and its desired temperature change you can calculate the corn flow.
