Automatic Sizing of Centerlines
NX7.5
There must be a way to automatically size hole centerlines (+). I really hate manually changing the size individually or by groups. I feel like there is probably a function that can dictate the size of the cross based on the diameter of the hole (i.e. I want the extensions to always cross the diameter of the hole). Any input is appreciated.
Design Engineer, NX 7.5
RE: Automatic Sizing of Centerlines
Thanks for the reply.
I know you can change it manually. What I really want is a function in my customer defaults that will automatically change those values based on the diameter of the hole.
Any ideas?
The "C" dimension is the distance from the edge of the hole, so it will change with the hole size.
