NX 7.5 import points for hole construction
Is there an easy way in NX 7.5 to import points with X/Y coordinates that will be used to create holes? I saw an old post about importing points via creation of a spline, then deleting the spline. This seems a bit excessive, so I am looking for a more streamlined method. In Inventor, there is a hole table where you can import this easily, so I am looking for something similar if it exists.
Thanks.
Thanks.
RE: NX 7.5 import points for hole construction
http://www.eng-tips.com/viewthread.cfm?qid=326967
this
You can use move object after you import the points if needed.
www.nxjournaling.com
To use points say by a x y grid the points can be created on a datum plane or a sketch for projecting to a body for hole creation. Again the points can be moved to also move the holes.
Frank Swinkels
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
